1st, 2nd, and OD on/off works. Changed the fluid - old fluid was pitch black. Tranny pan was coated in thick black junk. The tranny filter itself was surprisingly clean. No big chunks found - just a gross, black gunk. No codes from ECU or transmission diagnostic (tranny diag just blinks a constant fast blink, normal?). I also checked the TPS with the voltmeter and it is working just fine. Currently searching for a 5 speed to swap in, but the pickins are very slim in the Vancouver Canada area. Any ideas on the auto? I've used the search and have found a pretty shocking lack of info or help.
